02-15-2018 12:00 PM
I shot some pictures last night with my new Rebel T6, but when I transferred them to my computer from the memory card, they were too small (160x120). Resizing them only made them blurry. Is there a trick to working with this file, or a setting that needs to be changed? The Menu-> image quality is set at RAW, per factory spec, I guess.
02-15-2018 12:48 PM
What computer?
You were viewing the thumbnails embedded in the RAW. What software was used to view them?
02-15-2018 12:04 PM
Reset your T6. In the menus under Tools clear all settings. Set the mode dial to auto or P and try again. Outside on a nice day.
12-21-2018 06:47 AM
Just got this camera as a birthday gift, set it up per the manual, worked fine, put it away, when I showed it to my son in law it would not allow me to take a photo.
Looking for suggestions, have reset my t6 and still cant get the "function not avaiable" to go off regardless of what mode the camera is in.
I have tried removimg and reinserting the battery, this didn't help.
It's under warranty, maybe I should take it to a service center ?
Thanks,
Ismael Torres
12-21-2018 08:34 AM
I would try calling Canon for support then if they can't solve it over the phone, it is new return it for a replacement. Have you tried a new SD card? A full-size SD card the type and class recommended in your manual not a micro SD in an adapter.
12-22-2018 12:45 PM
"...have reset my t6 and still cant get the "function not avaiable"
If resetting your camera did not restore it, you need to call Canon 1 (631) 330-5000 Skip the rest of the baloney and give'em a call as long as you are in the USA and bought it in the USA. If not good luck.
02-15-2018 12:48 PM
What computer?
02-15-2018 09:12 PM
12-21-2018 09:05 AM
12-21-2018 10:23 AM
12-21-2018 04:54 PM
@SalT1945 wrote:
Brand new card, i’ll try Canon, appreciate the help, i’ll post something if they help me resolve the problem.
Which “function is not available”? Some functions are not available.
