02-12-2017 03:39 PM
I am new to the forum and asking for help. Our granddaughter plays basketball and I would like to photograph her. I kayak and would like to photograph birds. Is the EOS 760D the camera for me? Other? What lens or lenses? How can I protect my equipment form damage from saltwater? Thank you.
02-26-2017 10:53 AM - edited 02-26-2017 10:56 AM
@lurechunker wrote:
My 80D with 18-55 from Canon store will arrive tomorrow. I think I made a mistake by not getting the 28-135. Should I leave the 18-55 in the box and send it back? I'd like to start with an "all-round" lens and one long enough for back yard birds.
Do you mean 18-135, instead of 28-135? The 18-135 lenses are pretty good. BUT, they will likely cast a shadow when you try to use the flash. I know that older 18-135mm lenses cast a major shadow on a T5, so I would expect a shadow on an 80D. The 18-55mm lens has a 35mm equivalent of 29-88mm, which is pretty close to 24-70mm that is very popular for use with full frame camera bodies.
The STM version of the 18-55mm is a really good lens. I would hang on to it. I can guarantee you that whatever plans you have for using the camera, you will find new scenarios to use it. I would keep the 18-55mm, and pass on buying a 18-135, so that you can budget more money towards your birding lens. If you can afford to do all of the above, then by all means, buy all of the lenses you want.
03-02-2017 08:22 AM - edited 03-02-2017 08:27 AM
@lurechunker wrote:What about buying a used or refurbished lens from B&H?
I am not sure if I have seen any Canon refurbished gear at B&H, not in the last few years for sure. If you want to buy Canon refurbished gear, then I would only recommend the Canon refurbished store. They will give you a one year warranty, not just a "guarantee" of some kind.
I think B&H has a fairly good and objective rating system for their used gear. I think much of it is a bit pricey, though. Many times they will offer used gear that is rated "good" that has an asking price that is more than what is being offered in the Canon Refurbished Store.
Check what the B&H guarantee and return policy might be for used gear. I've bought a used tripod head and a "hi-hat" tripod from B&H, and I think I had a 15 day return window, and a 30 day guarantee.
Good judgement needs to exercised when buying used gear. You must consider the source. You must consider the return policy, for which B&H has a good reputation. You must consider the cost/benefit of expensive gear without a warranty. You must consider can the used gear be repaired, if needed in the near future.
With used camera gear, there is always a risk of mold and mildew contamination. Canon's refurbished gear has that new gear smell to it, so I think the contamination risk is small to non-existent with Canon.
[EDIT]. If what you want is out of stock at the Canon Refurbished Store, be patient. Most of the items will be back in stock in a month, or two, or three. The "L" series lenses can sell out very quickly.
09-03-2017 06:48 PM
Anyone own the Sig 17-50? Opinions?
09-03-2017 07:27 PM
@lurechunker wrote:Anyone own the Sig 17-50? Opinions?
I do not own that lens, but don't you already own a lens that covers that range? If you have one, what is wrong with it?
For most landscape shots, you do not need a wide aperture. Just a wide lens, that is sharp and rectilinear. My above photo of the bridge was shot a f/8, with a 20 second shutter speed, at ISO 100.
09-04-2017 09:42 AM
"Anyone own the Sig 17-50? Opinions?"
I don't own one as it is just another entry level ef-s lens. I typically don't do crop lenses anymore. On that same range of zoom lens, I have used the Sigma 18-35mm f/1.8 DC HSM Art Lens for Canon and found it to be outstanding. It just might be the best lens made in this range. Probably is ! Actually any lens in the Sigma 'Art' series is pretty darn good. I own several on them.
08-14-2017 09:18 AM
08-31-2017 07:41 AM
