02-12-2017 03:39 PM
I am new to the forum and asking for help. Our granddaughter plays basketball and I would like to photograph her. I kayak and would like to photograph birds. Is the EOS 760D the camera for me? Other? What lens or lenses? How can I protect my equipment form damage from saltwater? Thank you.
02-26-2017 10:53 AM - edited 02-26-2017 10:56 AM
@lurechunker wrote:
My 80D with 18-55 from Canon store will arrive tomorrow. I think I made a mistake by not getting the 28-135. Should I leave the 18-55 in the box and send it back? I'd like to start with an "all-round" lens and one long enough for back yard birds.
Do you mean 18-135, instead of 28-135? The 18-135 lenses are pretty good. BUT, they will likely cast a shadow when you try to use the flash. I know that older 18-135mm lenses cast a major shadow on a T5, so I would expect a shadow on an 80D. The 18-55mm lens has a 35mm equivalent of 29-88mm, which is pretty close to 24-70mm that is very popular for use with full frame camera bodies.
The STM version of the 18-55mm is a really good lens. I would hang on to it. I can guarantee you that whatever plans you have for using the camera, you will find new scenarios to use it. I would keep the 18-55mm, and pass on buying a 18-135, so that you can budget more money towards your birding lens. If you can afford to do all of the above, then by all means, buy all of the lenses you want.
03-02-2017 08:22 AM - edited 03-02-2017 08:27 AM
@lurechunker wrote:What about buying a used or refurbished lens from B&H?
I am not sure if I have seen any Canon refurbished gear at B&H, not in the last few years for sure. If you want to buy Canon refurbished gear, then I would only recommend the Canon refurbished store. They will give you a one year warranty, not just a "guarantee" of some kind.
I think B&H has a fairly good and objective rating system for their used gear. I think much of it is a bit pricey, though. Many times they will offer used gear that is rated "good" that has an asking price that is more than what is being offered in the Canon Refurbished Store.
Check what the B&H guarantee and return policy might be for used gear. I've bought a used tripod head and a "hi-hat" tripod from B&H, and I think I had a 15 day return window, and a 30 day guarantee.
Good judgement needs to exercised when buying used gear. You must consider the source. You must consider the return policy, for which B&H has a good reputation. You must consider the cost/benefit of expensive gear without a warranty. You must consider can the used gear be repaired, if needed in the near future.
With used camera gear, there is always a risk of mold and mildew contamination. Canon's refurbished gear has that new gear smell to it, so I think the contamination risk is small to non-existent with Canon.
[EDIT]. If what you want is out of stock at the Canon Refurbished Store, be patient. Most of the items will be back in stock in a month, or two, or three. The "L" series lenses can sell out very quickly.
07-09-2017 03:54 PM
I received the 1.4 Canon extender from B and H on Friday. I have shot doves, ducks, butterflys, cranes, cardinals and a wasp..even a dragonfly at 50 meters. Some of the shots are sharp and many are not. Would B and H take it back? What should I get? Maybe a Canon 2.8 70-200? A Tamron 150-600? A sig 150-600? Other? I like DPP and would like to stay with it. I understand that I could not use it with "third party" lenses. I look forward to your help.
07-09-2017 07:13 PM
B&H has a great return policy. I have returned a few items because they were not quite what I expected. You fill out a claim online, explain why, and you get an RMA number and shipping label one buisness day later.
If you can get some sharp photos with the 1.4x, then that should tell you that the extender works, and works well. If you want to get serious about your photography, then you might want to invest in Lightroom 6, while they still sell a stand alone license.
I would recommend Photoshop Elements, too, if it can stack macro photos.
07-09-2017 08:16 PM
I want something with longer range than my 100-400. I also want sharp inages. I like to do birds and some are not close. Do you recommend the Tamron 150-600 G2 for me? Does Tamron have a program like DPP? I will need to resize the images for email. Thanks.
07-10-2017 08:39 AM - edited 07-10-2017 12:15 PM
The big Tammy will not work any better or worse than the 100-400mm with the extender. It is likely you are inexperienced and will take some time to learn how to use big lenses.
"Does Tamron have a program like DPP?" No they don't. You need to get Lightroom or PS Elements. Probably Elements is better for you.
07-10-2017 10:02 AM
@lurechunker wrote:I received the 1.4 Canon extender from B and H on Friday. I have shot doves, ducks, butterflys, cranes, cardinals and a wasp..even a dragonfly at 50 meters. Some of the shots are sharp and many are not. Would B and H take it back? What should I get? Maybe a Canon 2.8 70-200? A Tamron 150-600? A sig 150-600? Other? I like DPP and would like to stay with it. I understand that I could not use it with "third party" lenses. I look forward to your help.
You're giving up far too early on the extender. I bought that same extender a few mnths ago (part of a package deal) and used it for the first time the other day on my 70-200 f/2.8. I couldn't see a bit of degradation in either image quality or sharpness. Conceivably there may be something wrong with your copy, but it's much more likely that your problems are due to your inexperience with it. It will be under warranty for a year, so you have time to try to learn to use it properly.
Remember that the extender increases the focal length of your lens. Which means that you need to be even more careful to avoid vibration or other unnecessary movement. Use that fact as a starting point as you trace the learning curve.
I can't help noticing that you seem to have a short attention span. That's not a useful trait for a serious photographer.
07-10-2017 10:21 AM
07-10-2017 11:50 AM
Of this group of 150-600 lenses, do you like Tam G2, Sig C or Sig S?
07-10-2017 12:23 PM - edited 07-10-2017 12:24 PM
Oh, by far, the Sigma S is the best. But it is extremely heavy as it is built to the level of Canon "L" lenses. All metal, no plastic. Even the hood is metal. I love mine and it is my goto tele lens. Did I mention it is very heavy? You need to try it before you buy one.
Of the other two offerings in this class, it is a toss up. Your choice. I slightly prefer the Tamron because it has some effort at weather sealing. The Sigma C doesn't. But the Siggy C has a dock that lets you update the firmware and soem other stuff of the lens. That may be a plus or it might not. Depends on you. I have both, actually all three of these lenses, and besides the S I prefer the one I am using at the time!
The S is in a class all by itself. It is a lens that Canon should have or needs to make. C'mon Canon get with the program here.
07-10-2017 12:26 PM
BTW, if you were experiencing trouble with the 100-400mm you might want to steer clear of the Siggy S.
07-19-2017 01:16 PM
Canon 100-400 L ll vs Tamron 150-600 G2. I have both but can keep only ONE. I will appreciate your expert opinions if you have first hand knowledge of one or both.
