12-01-2012 10:27 PM
When using my T4i when pushing down part way on shutter button flash makes a static noise then fires
is this noise for red eye reduction is this normal.
Thanks
Chuck
12-01-2012 11:49 PM
12-02-2012 05:57 AM
Ditto what JoeN said.
Noise that sounds like "static" is probably the image-stabilization (aka "IS") feature of the "kit" lens.
http://www.usa.canon.com/cusa/consumer/standard_display/Lens_Advantage_IS
You can turn off IS with the switch on the lens to confirm.
Flash charging sounds more like a high-pitched whine, usually.
12-02-2012 09:44 AM
Thanks.
When i put either 18mm to 55mm or the 75mm to 300mm kit lenses to manual mode the noise
disappears and the red eye reduction light glows yellow. Is this noise all coming from the kit lenses.
Thanks Chuck
12-02-2012 11:44 AM
