Reply
New Contributor
Accepted Solution
Movie Recording Has Stopped Automatically?
[ Edited ]
Hello,
I have recently purchased a Canon EOS Rebel T6 with a Sandisk Ultra Plus SD Card with 64GB and 100 MB/s speed.
When filming a video of myself in 1920x1080 quality, the movie recording stopped roughly around 12 minutes.
I assumed for it to atleast stop around 30 minutes?
Even if it stops, it doesn't even continuously record and make a new file when the recording stops, it just stops and I don't notice it stopping until after I was finished recording my video.
If there's a way to make it exceed 12 minutes or even just continuously record and make a new file when the recording stops, I would like to know.
I have researched hours on this topic and cannot find a solution. I truly don't think it's my SD card that's the problem.
Thanks.
Honored Contributor
Re: Movie Recording Has Stopped Automatically?
Not to be rude, but did your research include reading the instruction manual?  In addition to a 30 minute limite, you also have a 2 GB file size limitation, which is imposed by the file system of the SD card.
There is chart in the manual that illustrates how much maximum recording time, and file sizes, that you can can expect with different recording modes and SD card capacities.  In addition, the T6 does not automatically continue recording in a new file once it has reached maximum recording time, or file size.
New Contributor
I did actually read the instruction manual.
On the chart, it says that recording at 1920x1080 with a 64 GB card should record for 2 hr. 25 min.
But on the bottom it says that the file limitation of one movie clip is 29:59 min. (It stops when it reaches 4 GB)
But mine doesn't stop at 29:59, it stops at 12.
Even when I record in 1280x720, it still stops at 12 minutes.
Is there something I can do to fix this?
PS. When I record, my SD card is empty, there's nothing in it.
Valued Contributor
[ Edited ]
Your card may have 64GB capacity, but the way the file system works, 4GB is the max file size, and video will stop recording when it reaches 4GB.
Your 64GB card can hold a total of 2 hrs 59 mins of video, but it will be made up of multiple 11 min files. ( 4GB each)
If you record in 640x480 you can record up to 29 mins 59 secs before it stops recording.
Mike Sowsun
S110, SL1, 80D, 5D Mk III
Honored Contributor
Okay, the file size limit is 4 GB, not 2 GB.  Thanks, Mike.
powered by Lithium
