Reply
New Contributor
Memory card compatibility - Rebel T1i
[ Edited ]
Hi All -
I'm a newbie here.. just digging out my old camera and it's been a long time since it's been used. Well last night I learned that any SD card over 32 GB (SDXC) is not compatible with this camera. (Also not compatible with my point and shoot camera which is a Powershot S90) So now I have this 64 GB memory card I cannot use. Anyway.. I am trying to find the best (highest quality) alternative that WILL work with this camera. Does anyone know if there are any limitations on types of SDHC cards? Do you know if this one will work?
[link removed per forum guidelines]
I don't want to end up with another that won't work. I understand my technology is aging, but it works perfectly otherwise. I'd like to pick it back up and use it for a while to know my interest still exists before I invest in something new (I love new technology, so it's bound to happen eventually).
Thanks in advance for any tips/info!
Honored Contributor
Re: Memory card compatibility - Rebel T1i
Stick with full size cards by major brands like Lexar and Sandisk.  Use 32 GB, or less, although you really do not need that much space because of T1i camera's file size.  I think 8-16 GB would work just fine.  Be sure to perform a low level format in the camera befor you begin using any new card.
New Contributor
I was looking at Sandisk cards. Like the one below (wouldn't let me paste the link).
SanDisk Extreme Pro 16GB SDHC UHS-I Card (SDSDXPA-016G-X46)
Will that work? Basically my question is: will all SDHC cards work, or are there limitations?
Honored Contributor
That card should work.  Use the type of cards that were available when your camera was released.  Consult the owners' manual.
Esteemed Contributor
And the manual says this:
New Contributor
Yeah I've seen things like that online. But even SDHC cards have changed a bit since 2009. I'll give it a try. It's not expensive.
Honored Contributor
Cards have changed, but the camera has not.
That card should be fine.
1D X, Rebel T5i, Many lenses, Pixma PRO-100, MX472
New Contributor
Just bought a 32gb 90MB/s 600x and it worked. It’s a SanDisk Extreme PLUS SDHC UHS-I
On the package cover it has the little 3 inside a U then V30 with a little 4 next to it and the 4K UHD sign. This was the top one under $20. Hope this helps!
powered by Lithium
