Reply
Occasional Contributor
Marks showing up in Photos
I am noticing what appears to be an upside down hook mark showing up in some of my photos, about 3/4 of the way across the photo.  Any suggestions as to what may be causing this? And what I can do to correct this?
I have a Canon EOS Rebel T5 which a few different lenses, so I'm not sure whether its the camera or one of my lenses.
Thanks in advance for any help.
Honored Contributor
Re: Marks showing up in Photos
Post a sample picture of it.  It could just be dust on the image sensor.  Do NOT try to clean it, or wipe it off, though.
Honored Contributor
Just as I suspected. Dust.
You have a dirty image sensor.  It appears to be dust, which is removed by using bulb blower tool, like a "Rocket Blower".  If you do not have any simple cleaning accessories like a bulb-style blower and lens wipes, you should.
Thanks so once I purchase a rocket blower - this is something I can remedy?
Honored Contributor
Yes, this is minor.
Look on YouTube for videos that show you how to use a bulb blower to clean a DSLR.  Do not use your mouth to blow inside of the camera body, because your mouth contains moisture,  Moisture is the enemy.
You will need to remove any lens, go into the menus, and raise the shutter for manual cleaning.  Point the front of the camera downward, so that dust and dirt can fall out of the camera, and use a blower to gently puff air all around the sensor, and inside of the camera body.
powered by Lithium
