11-28-2012 02:51 PM
11-28-2012 04:54 PM
check to see if you have any bent pins in the card dock.
11-28-2012 06:43 PM
A little more information on exactly what is happening would help but if it's going in most of the way but not the last 1/4 inch or so a bent pin would sound like a correct diagnosis. A good light & a little patience with a jewelers screwdriver might set it back to it's normal position.
11-29-2012 01:02 PM
@Scatterbrained wrote:check to see if you have any bent pins in the card dock.
First, the XTi uses SD cards. No "bent pins" there.
Second, I wish people would realize that these subject only, no text in the body, posts are spam and not serious.
Probably Nikon fanboys having fun.
11-29-2012 03:30 PM
You may be correct about the SPAM, and because I didn't know what type of card the XTi uses I looked it up before posting a reply. You should have too.
http://www.canon.ca/inetCA/arcproducts?m=gp&pid=2987#_030
11-29-2012 07:38 PM
@cicopo wrote:You may be correct about the SPAM, and because I didn't know what type of card the XTi uses I looked it up before posting a reply. You should have too.
Whatever. I'm actually sick of wasting my time on these forums. Was decent before they opened it up to the masses
Toodles.
11-30-2012 02:26 PM
We'll miss you
11-29-2012 04:31 PM
xTi uses CF cards.
Maybe the OP is putting them in facing the wrong way.
