09-25-2013 06:29 PM
09-25-2013 08:10 PM
If you push the flash button (side of lens mount area) does the flash pop up?
If so, what shooting mode are you using? Certain auto modes disable flash, as does full manual.
Also, check out the Flash Control settings under one of the menu options, just in case something got switched accidently.
09-26-2013 01:15 AM
09-26-2013 11:24 AM
If you're in P mode, in a dark room, it should pop up. Did you check the flash control menu?
