Reply
Highlighted
Honored Contributor
Re: EOS Rebel SL1 DSLR Is Suddenly on Crack
[ Edited ]
Mr_Fusion wrote:
Micro SDHC cards are very acceptable. The "micro" refers to the physical size and nothing else. Manuals don't specifically differentiate or point to micro cards simply because an SD card is an SD card, regardless of the size.
It is a myth and bad practice to advise others without a solid reason. If you can point to any legitimate source that says NOT to use micro cards, then please cite it. In the mean time, every major AD manufacturer states their micro cards work well in cameras. Again, the ONLY caveat is in videoing 4k where heat may be a problem
From time to time, Canon Moderators and Product Experts have pointed out that micro-SD cards are not recommended.
The manuals say to use type A, B, or C, but makes no mention of type D.  Your conclusion is that it is okay to use type D, because the manual does not specifically say not use type D.
But, you can do whatever you wish to do.  Your reasoning is highly flawed.  Claiming that manuals do not specifically say do not use micro-SD cards as justification for using them is most illogical.
Super Contributor
Mr_Fusion wrote:
"There is no reason NOT to use a micro card and adapter in any Canon camera."
You mean other than the introduction of an additional, unneccessary part that can fail.
"Only buy from a reputable outlet, such as B&H, Adorama, and Best Buy."
Is an adapter or SanDisk memory card from Best Buy better than the ones from Newegg?
VIP
"From time to time, Canon Moderators and Product Experts have pointed out that micro-SD cards are not recommended.
But, you can do whatever you wish to do.  Your reasoning is highly flawed.  Claiming that manuals do not specifically say do not use micro-SD cards as justification for using them is most illogical."
My thought exaxtly and I didn't have to type it.  Smiley Happy
A lot less stuff for 2018 but still a lot of Canon stuff. Along with, a lot of other stuff.
Frequent Contributor
We've had enough people write in with complaints that went away when they stopped using micro-SD cards to convince us that they're a bad idea, no matter how one interprets Canon's recommendations. We couldn't care less that you think we're all wet, and we can't stop you from telling others that we are. But here's what I'd say to anyone who asks why he should take our advice rather than yours: "There is no more mission-critical device in your camera than the memory card. If it doesn't work correctly, your photo shoot is toast. The most common memory card failure is poor contact between the card and the camera. By using a micro card, you add an extra set of contacts for no compelling reason. Why would you want to introduce this unnecessary risk factor?"
Anecdotal evidence is not "scientific evidence". Again, there is no difference in quality between a full size card and a micro size card. You don't know why the "problem went away". Possible explanations include counterfeit cards, mishandling the cards, or even foreign debris inside the camera.
If you want to think you are all wet, that is your own emotions. I'm working off of facts. I would much prefer to discuss facts than projections.
There is no question that the recording medium is important. It though, is only one component in a system where any single failure can stop the mission. Suggesting it is THE most important component is an emotional argument, not factual.
The most common type of SD card failure is from counterfeit cards.  Every time a card is removed and then inserted into something else causes wear. Every time you handle a card with those exposed contacts you risk damage. Every time you insert them or put them into a sleeve you risk damage. Leaving a micro SD card in its adapter and leaving that in the camera does not.
An extra set of contacts? That isn't how it works. Once the contacts are in place, they don't move. This connection is little different than most of the electrical connections in the rest of the camera. The ONLY wear will come from removing and reinserting the card.
There is norisk factor in using a micro card although there is in changing cards.  Myths and false understanding are generally far more dangerous than anything. Use your personal preference all day. But don't share myths as fact when the best you (plural) can come up with are anecdotal claims and non-existent technical reasons.
[ Edited ]
The only ones I see claiming not to use micro SD cards are a few here. Anyone claiming that a micro SD card can not perform similar to a full size card does not understand how memory cards work.
What the manuals refer to are form factors. Those are important simply because they need to attain a minimum read / write speed and characteristics. Not all electronic devices can read / write to the latest specifications. As far as I know, all Canon cameras support the various SD form factors; SD, SDHD, SDXC, and USCs.  When a manual specifies the SD card form factor, the size of the card is not relevant. Those are two separate things. Using the form factor to argue the size acceptance is misguided. (The manual specifies a Speed rating of 6 although I personally recommend a Speed of 10.)
I still wait for a cite that micro SD cards are to be avoided in Canon cameras. . Anecdotal experience is not a legitimate source. As I wrote elsewhere, counterfeit cards are a far larger issue than anything else.
[ Edited ]
An additional part that may fail?  Are you serious?The adapter is a straight mechanical connection, the card or camera will most likely fail before the adapter. Any adapter from any member of the SD Consortium is built to the same standards as the cards. The connections should have the same rate of failure as the connections on a card.
The only thing that will cause an adapter to fail is repeat handling and poor storage, and that would be mechanical damage.
Is Newegg a "reputable outlet"? I have never had a problem with them, but I haven't bought anything from them in a few years. If you find them reputable, then buy from them.
Esteemed Contributor
All evidence is anecdotal. Science consists of analyzing a body of anecdotal evidence and proposing a theory that explains it. Scientific "fact" is nothing more or less than what can be deduced from theories that have not been disproved.
Everything in your post is opinion. So is everything I said in the post that you quoted above. That's fine: we're discussing risk analysis, and risk analysis consists of weighing conflicting opinions and deciding which one makes the most sense. I think mine makes more sense than yours. The reader can judge for himself.
Bob
Boston, Massachusetts USA
VIP
"I'm working off of facts. I would much prefer to discuss facts than projections."
Ok here is a fact for you.  Canon did not design their camera to use micro-SD card adapters.  They designed it to use an SD card.  I doubt any company is going to list all the things you should not or can not use.  Now it makes not a rat's petutie to me what you use but saying the adapters are perfectly fine is just as bad as saying they aren't.  Now that's a fact.
BTW, I don't even like SD cards much preferring CF cards.
Honored Contributor
I agree.  Anecdotal experience is not a legitimate source.  However, all of your "facts" have been anecdotes from your personal experience.  Personal opinions are not facts, either.
BTW, I have already presented facts, the instruction manuals that specify using types A, B, or C.
 - BTW, I have already presented facts, the instruction manuals that specify using types A, B, or C.
SD cards do not come in "A, B, or C". They come in SD, SDHC, and SDXC. The manuals all specify those cards. https://www.sdcard.org/consumers/choices/file_system/index.html
powered by Lithium
