03-06-2017 07:30 PM
03-06-2017 08:02 PM
Forget the filter. Use a lens hood for bump protection and stay out of rain and water spray.
A cheap filter will likely degrade image quality.
There are times for filiters (polarizer, neutral density filters) but for a beginner on a limited budget be careful and enjoy learning your hobby.
03-06-2017 10:46 PM
03-06-2017 11:02 PM
Look on Amazon. Search for lens hood for your lens and get the cheapest one. Should be under $10 each. Unlikely that both lenses use the same one.
03-07-2017 04:34 AM
"...my lenses (18-55mm and 75-300mm)?"
This is a hotly contested issue. To use protecto filters or not. I am generally on the side of, always use one. The down side to using protecto filters is so small as to not be a problem at all. It is always over stated. Plus, if the situation arises you can always remove the filter. Lots of folks seem to forget filters screw off just as easily as the screwed on!
The real truth is filters are largely obsolete. Their time has come and gone with the digital age. The few exceptions are the protecto and perhaps an ND or polarizer. But even they are mostly obsolete, too.
On some Canon lenses a protecto filter is mandatory for full weather sealing. Canon states this in the manual for the lens.
Now to answer your question specifically, the benefit must be considered. You do need to buy high quality filters. You need to compare that vs the cost of your lens. On a $1000 dollar lens a $50 or $60 dollar protecto filter is a small price to pay for the protection. The same filter on a $100 or even a $200 dollar lens is not such a good value is it? I would skip the filter in your case as others have suggested.
A hood does offer a small amount of prtoection but it is an item that you should use all the time anyway. So, it has two advantages.
Personally, I have protecto filters on almost all of my lenses. They all have hoods, too.
03-07-2017 12:24 AM
I wouldn't worry about any filters immediately. Filters can create reflections and ghosting which would degrade image quality. Better filters have good anti-reflective coatings and these help ... but it's still possible to get reflections even with these.
In some environmentally hostile shooting situations it might be helpful to have a filter on the front of the lens... but that's infrequent and most of the time the filter isn't needed.
03-07-2017 06:41 AM - edited 03-07-2017 06:43 AM
@kitkat wrote:
I recently bought a Canon T5 bundle without really knowing the first thing about cameras. I'd like to learn, though, which is why I bought it.
My mother tells me I absolutely, definitely, 100% must get a lens filter to protect the lens, but I've read conflicting theories on whether or not it's a good idea, so I've come here to ask. I have heard people say that lens hoods give better protection, but I'm still unsure.
I got the camera on clearance for very cheap, and I'm on an extremely limited budget, so I'm unable to spend a lot on accessories, but I also don't want to fail to protect what I've got.
For your EF-S 18-55 IS and EF 75-300, no you are not going to want to use a protective filter. If you use protective filters they have to be top quality filters to avoid degrading the image quality. The problem is a top quality filter will cost well over half the replacement cost of your lens. So in cost benefit terms you are much better off taking the small risk of damaging your lens and having to replace it vs spending more than half that cost to try and protect it. If you just buy a cheap filter you are going to hurt the image quality of your photos.
Get a bulb blower like the Rocket Blower. Get a brush designed for lenses like the LensPen. And get some Zeiss Lens Wipes. Use the minimum amount of cleaning needed. Always use them in this order, Rocket Blower, Lens Brush, Zeiss Lens, Wipes, cup end of the LensPen. If a Rocket Blower works, stop there. Always use the minimum amount of cleaning needed. More isn't better when it comes to caring for your lenses.
03-07-2017 07:00 AM - edited 03-07-2017 07:54 AM
Others have already pretty much exhausted the pros and cons of protective filters. If you do buy a filter, I would recommend buying a clear filter. You do not need a UV filter because there is a UV filter built into your digital camera.
If you do buy a clear protective filter, then it will not be as expensive as previously described. Your lenses will need a 58mm filter, which costs about half of previous estimates. I would recommend the B+W 58mm XS-Pro Clear MRC-Nano 007 Filter. The same filter can fit either of your lenses, so you can buy one filter, or two.
The best course of action may be to keep Mom happy. Buy the clear filter, not a UV filter. For technical reasons, nearly all digital cameras have a UV filter built into their image sensor assembly. With the use of a filter, then the use of a hood, to shield the filter from light hitting it from angles outside of the field of view, becomes all the more important. Look for 3rd party hoods, too..
03-07-2017 08:45 AM
I got the camera on clearance for very cheap, and I'm on an extremely limited budget, so I'm unable to spend a lot on accessories, but I also don't want to fail to protect what I've got.Others have already pretty much exhausted the pros and cons of protective filters. If you do buy a filter, I would recommend buying a clear filter. You do not need a UV filter because there is a UV filter built into your digital camera.
I don't see any reason to prefer a "clear" filter over a UV filter; I'd buy whichever one is cheaper. And it wouldn't surprise me if the clear filter turned out to be more expensive than a UV filter of equivalent quality.
Ordinary window glass does a good job of filtering out UV. That's why hospital sunrooms, where unfiltered sunlight is considered beneficial, use special glass that doesn't filter UV out. Auto glass filters UV, which is why photochromic sunglasses don't work well in a car. The glass used in lenses does pass UV (or at least some of it), and in the film days many films were sensitive to UV. This was considered detrimental in most cases, hence the use of a UV filter. But as Waddizzle points out, digital cameras get rid of UV before the light hits the sensor, so whether an additional filter passes UV or not is irrelevant.
03-07-2017 09:03 AM
Just to reiterate - cleaning "supplies" should be limited to a Rocket blower or similar device. Squeeze to blow dust of the lens surface.
Never use canned air or other such product.
Until you gain experience and understand what is going on don't try cleaning anything inside the mirror chamber. Too many horror stories posted on the orum of folks who did that and damaged parts. When you chnage lenses keep the camera opening facing down and don't do it when dust/breeze is blowing.
