11-15-2016 07:50 PM
11-15-2016 09:49 PM
We need more details. Is this in the JPEG files or just on the LCD?
11-15-2016 10:06 PM
11-16-2016 04:59 AM
@CamMAN wrote:
I am using my canon t5 for live streaming via hdmi out in to a blackmagic mini capture card
What "white squares"? The HDMI output on a T5 is a reproduction of the LCD screen. It was never intended to be used as a video signal for recording.video.
The Rebel T5 is [or was] Canon's most basic entry level DSLR. It is primarily designed to introduce people to still photography using a DSLR. The fact that it can record video is a side effect of having all of the hardware to do so. For example, many smartphones can record video, but recording video is hardly their main purpose or feature.
11-26-2016 12:58 PM
11-26-2016 04:26 PM
@CamMAN wrote:
Can the t5 get a clean hdmi output?
Negative.
As I previously noted, the HDMI output is a repeat of the LCD display on the camera. The HDMI output is intended to allow a camera operator to connect an auxillary display monitor that is larger than the LCD. When you plug a connector into the HDMI port, the video signal going to the LCD is rerouted to the HDMI output port.
The HDMI is not a "clean signal" for use as a video signal for recording.
