Reply
New Contributor
Canon eos rebelt t7i won’t turn on
My canon t7i won’t power on even though the battery is  charged and has it’s memory card in it. The little light at the bottom flashes red as soon as i close the battery door/latch but when i swith the camera on it wont turn on can someone help me please !!!
Honored Contributor
Re: Canon eos rebelt t7i won’t turn on
Try removing the card, and powering it up.  You could have an issue with the memory card.  What type of card?
If you see the light flash when you close the battery door, that should be a sign that it is properly closed.  You could also have a display failure.  What do you see in the viewfinder when you press the shutter?
New Contributor
i can see through it but nothing happens when i press the shutter nothing happens when i turn the on button
Honored Contributor
Contact Canon US Suppport.  Sounds like your camera is malfunctioning.  1-800-OK-CANON
New Contributor
do you think it’ll be expensive to fix like i have taken care of that canera good i haven’t had it for a year yet and have never done anything to mess it up
Frequent Contributor
It's impossible to know how expensive it will be to fix until you send it in. After you send it in, you'll be provided a quote so you'll know how much the repair will cost before you approve it.
______________________________
I'm a cinematographer in Chicago using mostly Canon gear. I also founded MKE Production Rental in Milwaukee.
Honored Contributor
Your camera should be under the first year warranty.
powered by Lithium
