Reply
New Contributor
Re: Camera saying busy and won't take pictures
I discovered that the lense wasn't correcty inserted in the camera. You couldn't see anything to indicate a problem. A friend who have an EOS checked the camera and now it works find.
Frequent Contributor
Excellent. What a relief. Way to go! Now your solution can help others.
New Contributor
hi all,
I'm having the same issue on my rebel t3. it will sometimes not take a photo and says that it is 'busy' when I try to take the photo in auto modes. this doesn't happen all the time and this doesn't happen in similar lighting conditions. I'm using a tamron 18-270 on it now, but I've tried it with a 50mm and the 18-55 kit and that doesn't make a difference. please help!
Do you have a Class 10 card in the camera that has been formatted IN the camera?
New Contributor
hi,
yes, I do have a fairly new Sandisk class 10 card that was formatted in camera. actually after formatting in camera that fixed my problem, but now there is a dot that will flash next to the max burst rate 9 when I press the shutter button. any idea what this is?
thanks!
Occasional Contributor
My fix to this problem was repair at $270, which was a new main board.
I had same problem, I tried everything, including new memory card, new battery, format old memory card that had always worked before, no help. Finally i sent it off for repair, cost $270, problem was diagnosed as bad main board.
Glad your camera is working again. Thanks for updating this thread so others can see your successful solution.
Check manual about burst rate light because I bet it's not just the camera saying "hello".
You certainly did try all the cheap and easy fixes first.
Ouch. So sorry $$$$. It would seem that you now have a brand new camera that will serve you well for many years.
New Contributor
I had this same problem with my old film EOS Rebel camera and now am having it with the digital EOS Rebel SL1.  I despair.  I love this camera but after two years I get a busy signal and then slowly it stops working altogether.  Please elp.
powered by Lithium
