Reply
New Contributor
Re: Camera saying busy and won't take pictures
Hello everyone, I bought the Canon 70D, as it's called over here in Europe, and I'm experiencing the same issues that people are reporting on the forums of this and many other websites.
It seems to me when I shoot a few images at a time then it locks up and won't write more than 3. Almost like it will buffer upto three then it will just say "busy" and not write them to the card, or take new ones.
So far I tried the following:
 • different lenses (Canon and other makes)
 • different memory cards (of differing capacities)
 • reformatted those different memory cards
 • bought new "Ultra Fast" card
 • turned the camera off fully between shots (rather than letting it "sleep")
 • altered the position in which it sits in my bag
 • different focus modes
 • used manual focus rather then auto-focus
The only thing left is to reset it in the settings menu... I just wanted to ask if anyone had any success with this or is it just something we have to live with? I have to say if it is somehting we need to deal with daily then I will be sorely disappointed as I've previously had 15 years worth of perfection from Canon DSLR Cameras.
Thanks in advance to everyone who is trying to figure this out.
Cheers
Mark.
New Contributor
Thanks for this!  You saved me!
Frequent Contributor
[ Edited ]
I have (3) T4i's and shoot with all three almost every week.
I have had no "camera busy" etc. messages since changing to (1) Transcend Class 10 200x 32gb in one (2) PNY Pro-Elite Class 10 32GB in 2nd body (3) SanDisk Extreme Class 10 32gb in the 3rd body.
All are SD HC 1.
I do reformat the cards IN THE CAMERAS every few hundred shots and after doing videos.
I use only Canon lenses...18-135 zoom STM, 24mm STM, 60mm macro, 10-22 zoom.
I use Canon and Wasabi batteries.
One body has powergrip and others do not.
New Contributor
I have a Canon Rebel T3 that is about 3 years old. It took a small fall yesterday and is now giving me problems taking pictures. This is what I've observed:
1. Can't take pictures using the "kit lens" in AF mode (flash will pop up but picture won't take)
2. Pictures will take in MF mode
3. When I switch to "live view" I can sometimes get a picture to take but not always
4. I have tried another lens and can take pictures just fine
5. No matter what lens I use the "access lamp" light continues to flash
6. I have tried using a different SD card and still get the flashing light
7. I have cleaned the lens
I'm afraid I damaged my kit lens when the camera fell and need to replace it but I'm not sure. Is there anyway to fix this? Also why would the light continue to flash no matter the lens or the sd card?
If your kit lens was the one on the camera at the time of your fall AND it is the one lens that doesn't allow your T3 to function properly then you got off lucky as that is THE cheapest lens to replace.
I would not even try to use it anymore. The estimate on taking a look at it is more expensive or at least as expensive as buying a replacement lens of the same kind.
Look at this as an opportunity to upgrade your lenses and be thankful that it was only the kit lens and not your camera body.
The light flashing is the camera accessing the card probably and that is good. Also check your battery in the camera and make certain it is fully charged.
I have re-banged lens and they start working again but I only do that as a last resort before I toss the lens or sell it on ebay clearly labeled NOT WORKING FOR PARTS ONLY!
Good luck.
NOTE: By the way, you're not alone, I fell once while shooting a wedding and was reminded of it everytime I looked at the scratches on my usually perfect equipment.
New Contributor
I am having the exact problem as stated above, however, I have tried multiple lenses and they all produce the same results... It tries to focus but will not shoot a photo. Please help!
Check the earlier parts of this discussion for the problem being the memory card and NOT the lenses.
Good luck!
New Contributor
I was almost  ready to give up on my rebel xs until I did some research online.  I went to the Canon sight and did a reinstall on the 1.0.7 firmware.  Seems to have corrected the problem!!!!!!!!!
New Contributor
Hello, I have the same issue where the  flash won't work on AF mode when using the 18-55 mm lens. However, when I switched to another lens (prime lens 50mm), it works fine. Does that mean the 18-55 mm lens malfunctioned?  is there a way to fix this? Thanks so much for your help.
Which flash are you using? Which camera?
powered by Lithium
