2 questions T3i recording to external source.
timmyg1978
How do I get the info on the screen to dissapear so it only shows the picture?
I want to record to my avermedia ez recorder plus so I can record longer than 12 mins, also, where can I find hd component cables for the t3i?
1 REPLY 1
Mykolas
Timmyg1978,
When you are viewing an image on the LCD, to change what information is displayed all you will need to do is press the <INFO> button.
In regards to using an external recorder, when the camera is in the process of recording or sitting idle, the signal coming out of the camera is not the same as what the final recorded video will be.  In order to get full HD video to the recorder, it must be recorded with the camera first, then played back into the recorder.  The limit will still be about 12 minutes of video.
Also, the EOS Rebel T3i does not have HD component outputs.  It outputs HD video via HDMI.
Enter for a chance to win!
April 20th-28th
