05-20-2023 03:53 PM
I have had the R5 and same Ascend CFexpress card for over a year. It worked fine. Over the last couple of weeks I have started to lose photos. I know they recorded, because I could view them on my camera and could scroll back through all of them. Multiple times, when I try to view them on my computer, they are lost. When I put the card back into the camera, they are gone. Earlier photos are still able to be seen, so not all photos are missing or deleted. What is going on?
05-20-2023 03:57 PM - edited 05-20-2023 03:58 PM
Have you tried using a different CF Express card instead. Does the other card slot exhibit this problem too. Is the camera set to record to both cards simultaneously. If so are the missing pictures on that card.
05-20-2023 04:18 PM
It has also failed the same way with a Sandisk CFexpress. I only use the CFexpress card, so no SD card is ever used.
05-20-2023 04:20 PM
Do you format the CF cards before first use in the camera.
