pics are blurry every pic I take with my Rebel T5
AngRae2
Just getting used to my Rebel T5 and I must have pushed a button and now every pic is blurry. Any help would be appreciated.
4 REPLIES 4
TTMartin
Make the the MF/AF switch on the lens is set to AF.
Then take a picture of something outdoors in the sunlight with the camera in 'Green Square' mode.
ScottyP
PLEASE learn the exposure triangle. There are many 3 minute vids on YouTube, etc.  Watch 4 of them and your answer will be clear.
Scott
ebiggs1
This is the correct answer.
"Make the the MF/AF switch on the lens is set to AF.
 Then take a picture of something outdoors in the sunlight with the camera in 'Green Square' mode."
Do this before learning anything additional.  If it works doing this test, there is nothing wrong with the T5.  Make sure the subject is around 20 to 25 feet from you.
If it does work and I suspect it will, you do need to learn more about your T5.
Just yesterday I was taking some RAW test shots with my T6S. I stumbled upon a preying mantis and took a few shots of it. When I got inside I saw that my DOF was pretty shallow and I had focused on his back, not his "face". Just a snap, so no big deal, but something I should have chimped on the LCD.
