R5 - Maximum shutter speed of 1/50 sec in video mode.
SunnyG
Hello
Is it possible to set for example 1/50 sec as a maximum shutter speed when in video mode?
With the R5 you can go down up to 1/8 sec wich can be a cool effect. But if you need to be fast and just scrolling the wheel to the max, I want to be sure to not go slower than 1/50 sec.
With the 5D mrk IV the framerate also resulted in the slowest shutter speed. That was very handy.
Thank you!
1 REPLY 1
rs-eos
I dont think you can. One nice feature of cinema cameras such as the EOS R5C or EOS C70 is using a shutter angle which would then automatically adjust the shutter speed based on the current frame rate. e.g. a shutter angle of 180° would use a shutter of 1/48 for 24 fps, 1/60 for 30 fps, etc.
Ricky
Camera: EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L
