06-12-2023 04:21 PM
06-12-2023 05:49 PM
Have you tried to power up the camera with the lens, SD Card and other accessories removed. From the camera to see if the camera will power up at all.
06-12-2023 05:55 PM
When I take off lens and remove sd card…I dont even get the flashing green light.
06-12-2023 06:01 PM
Will the camera power up with those items removed.
06-12-2023 06:07 PM
No…unfortunately it doesn’t…..when I take off the lens….I still get the flashing green light without powering up but when I remove the SD card…..I get no green blinking light along with it not powering up. Wondering if it’s a battery problem or a camera problem or something else.
06-12-2023 06:09 PM
If you have a spare battery test the camera with it. If it still behaves the same after using the spare battery you'll need to contact Canon.
09-19-2023 02:25 AM
I have the exact same problem ! Did you find a solution for this ? I still haven't found anything.
09-19-2023 08:17 AM - edited 09-19-2023 08:21 AM
@mahapjyo wrote:I have the exact same problem ! Did you find a solution for this ? I still haven't found anything.
Did you test with a second battery? Also with a second memory card? As a last suggestion, you should also try removing and remounting the lens to the body.
~CarePaks Are Worth It
02-09-2024 05:05 AM
I did, try a new battery and memory card. But the screen just wont show up.
02-09-2024 10:18 AM
If a new battery and card don't resolve with the lens detached, you will need to contact support.
