I cannot get the Autofocus to work with a Canon EF 1.4X III Extender and a Canon EF 100-400 4.5-5.6L
wcarter
Anyone know if the Autofocus will work with a Canon EF 1.4X III extender and a Canon EF 100-400 4.5-5.6L lens on a T3i? The compatibility chart says they will work together, but my T3i switches to manual no matter what I do.
5 REPLIES 5
cicopo
Not going to work That body can't AF at F8 which is now the widest aperture for the lens & TC combo.
diverhank
Auto-focus will not work, not because the EF 1.4X III is not compatible but because the combo raises the minimum aperture to f/8 - you lose 1 stop using the 1.4 teleconverter and with the 100-400mm being at f/5.6 that becomes f/8.
Some higher end Canon cameras such as the 1D series, the 5D mark III/IV and the 7D Mark II (not sure about the 6D) will auto-focus at f/8 but the Rebels won't.
The workaround would be to tape the 3 pins on the teleconverter and fool the camera into letting you focus (no f/8 report).  You can google the instructions easy enough.  The Autofocus performance may or may not be satisfactory though.  There is a reason why Canon disallows auto-focusing at f/8.
Diverhank's photos on Flickr
Thanks to Cicopo and Diverhank for thier help on this issue.  Maybe it is time for a full sensor Canon.
wcarter
The 7D mark 2 can AF with that combo. May only be the center AF point or expanded center set but it can AF.
The 80D center point can focus at f/8, too.  It's nearly a 7D Mark II, minus the weather resistant build.
