EOS M50 Display becomes "black" when NOT used under direct sun light
mrstevejobs
I have a pretty weird issue.
At first, I thought the display was broken. But suddenly I noticed that if I positioned myself with direct sun behind me, hitting directly at the LCD display, then I was able to see the display. Very dimmed and with a very low brightness, but it was fully functional.
As long as I put something stopping the sun from hitting the LCD, the display becomes completely "black". In other words. It seems that the more light the LCD receives, the more I can see the screen and the "brightness" it becomes.
It's kind of the opposite as it would normally happen!
It is just not possible to use the screen this way.
Does anyone know what's going on here?
Did the screen just get messed up somehow? Some cable connection, perhaps?
Thanks!
4 REPLIES 4
March411
Rising Star
Have you gone into the menu and tried brightening the display?
Be a different person on the web, be kind, respectful and most of all be helpful!
90D ~ 5D Mark IV ~ R6 Mark II ~ R50 and way to many EF lenses
Photoshop and Topaz Suite for image processing
http://commonhangout.com/piwigo/
mrstevejobs
Yes. Its at its maximum.
Still black when the sun doesn't hit it
Are you wearing polarized sunglasses when you notice this? Try rotating the camera 90° and see if it changes anything.
Are you using a polarizing filter on the lens or do you have a screen protector on the LCD? Does it happen when using Live View and/or when previewing images or menu screens?
It's possible of course that the LEDs that backlight the LCD screen have failed or there is a bad connection in the circuit that supplies power to them.
Definitely not 🤣
But I'll try the rotation when I get home, although I don't think it's a case of polarization.+
Nope.
All the time.
