11-21-2023 02:36 PM - last edited on 11-21-2023 02:37 PM by Danny
Hi All,
Canon 6D II
Is there a setting where you can look at the LCD screen initially then move to the view finder where it senses the closeness of the eye, activates view finder and then turns LCD screen off to conserve battery. I do not see an external sensor for this but thought I'd ask.
Thanks
Ken
11-21-2023 06:01 PM
Note that the 6D does not have an electronic viewfinder, so you *have* to turn the LCD live view image off to see the image in the viewfinder...
11-21-2023 02:51 PM
I think the functionality to automatically blank the rear LCD is already built into the camera, It is just not specifically associated with proximity to the OVF.
You can blank the screen by pressing the [INFO] button until it turns off. The screen can also be set to blank itself when you start the metering system when you half-press the shutter.
Of course, neither of the above methods work when the cameras is in Live View Mode.
11-21-2023 02:56 PM
Thanks for the useful information.
11-21-2023 06:01 PM
