02-01-2024 10:29 AM
I have a Canon printer, and I want to connect my new, HP laptop to it. I don't see a USB type port on the printer, though I do see a 'phone' cable type port. What kind of cable would I use to make the connection? As far as my laptop, it seems to only have an HDMI and a USB port.
Thanks,
02-01-2024 10:32 AM
Thanks for joining the conversation, gidmeister! The USB connection port on your PIXMA TR8520 is on the back of the unit. You'll need an A-to-B USB cable. The B-type connector has a square shape compared to the relatively flat rectangular shape of the A-type connector.
Hope this helps!
02-01-2024 10:32 AM
Hope this helps!
02-01-2024 05:34 PM
I had the same queation about my TR 4720 printer.
It would be VERY helpful if the information about needing a printer cable was included on the box. The way it's phrased makes it sound as though the printer -- like my two previous PIXMAs -- uses a regular USB cable, and this most decidedly does not. People generally want to be able to use a product straight out of the box without needing a second trip to Staples.
