09-03-2016 08:12 PM - last edited on 09-03-2016 08:53 PM by Jason
what ink do I use for Canon Pixma MG2100 series, the ink that it says it uses is PG-540XL for black. will the 240 work for this printer. Serial number is LMGB [Mod Note: Edited serial number per forum guidelines].
09-06-2016 11:31 AM
Hello.
If you purchased the printer here in the United States, you should be using PG-240 and CL-241 series ink cartridges.
Visit the following link if you would like to order them from our eStore:
If you purchased the printer outside of the United States, check the documenation for your printer to determine which cartridges are compatible with the unit.
