03-04-2018 04:08 PM
I am using the MS Word label maker. The word doc boders have been set to zero. The word label properties/sizes have been set up appropriately and have worked on another printer.
I have tried ts9020 printer settings of both standard and borderless. Borderless seems to expand the label image so is not working at all, besides printing with the addl quarter inch boundary.
Stardard with photo paper and high quality maintains the size of the label, but it is mis-positioned because of the extra quarter inch on the left.
Have tried from both paper tray and feeder. Paper is property positioned in tray/feeder, with 8.5 inch width adjustment. Same result either way.
Any ideas???
Thanks!
05-07-2018 12:22 PM
Hi wiff,
What kind of label paper are you using? If you are using Avery, please try using their templates:
https://www.avery.com/templates
If you are not using Avery paper, these templates may not work for you. Please check the manufacturer's web site of the paper that you using.
