09-25-2015 04:48 PM
I think I did something wrong when I first setup my printer and would like to reset and start all over. I can't find any where to do that on the menu
09-27-2015 09:46 AM
Hello.
Please follow these steps to reset the settings:
1. Go to the Home menu or press the Home button.
2. Select Setup.
3. Select Device Settings and press OK.
4. Select Reset Settings.
Once there, you can access the options to reset the settings.
If additional assistance is needed, find more help at Contact Us.
11-26-2015 04:14 PM
I followed your instructions for resetting. It reset the canon 7720, and turned the 7700 series offline, which I figure is a good thing, because I need the 7720 setting to work. Now the 7720 in online like it should be. I still cannot print from it however. This is becoming a vicous cycle. Any suggestions?
11-27-2015 11:41 AM
To have a better understanding of your issue, please let everyone know what operating system (Windows Vista/7/8 or Mac OS 10.X) you are using and if you are connected via USB or WI-FI. That way, the community will be able to assist you with suggestions appropriate for your product.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/EmailCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks!!
11-28-2015 05:28 PM
Yes, I am connecting with WiFi. And my system is Windows 10.
Thank you.
