how do I do poster printing on MX922
chris1045
This is a common printing task but I can't figure it out on the MX922. How to I print "hello" on say 3 x 6 pages and then tape together to make a big poster with the word? Thanks.
1 REPLY 1
James_C
Moderator
Moderator
Hi chris1045
https://support.usa.canon.com/infocenter/index?page=content&id=ART142093&actp=search&viewlocale=en_U...
You can perform poster size printing on multiple sheets using the following steps:
You can print a large image by dividing it across several sheets of paper.  In 'Image divisions' you can decide the number of pages over which you want to print the document.  You can also print the words “cut”, “paste”, cut lines or both in the margins as guidelines.
In the Printer Properties dialog box, on the Page Setup tab, follow the steps below.
1.  In 'Printing Type', select 'Poster Printing'.
2.  In 'Page Size', select the paper size specified in the application.
3.  In 'Orientation', select the same orientation as specified in the application.
4.  In 'Printer Paper Size', select the paper size loaded in the printer.
5.  Click 'Specify'.
6.  In the Poster Printing dialog box, in 'Image divisions', select the number of pages on which to print the poster.  The image is enlarged according to the settings in 'Printer Paper Size' and 'Image divisions', and regardless of the document size.
7.  To print cutting lines on the paper, select 'Print “Cut/Paste” lines in margins'.  To print the words “cut” and “paste”, select 'Print “Cut/Paste” in margins'.  Windows 2000/XP: Specify the print range.  To print all pages, click 'All'.  To print a range of pages, click 'Pages', then enter the page numbers you want to print.
8.  Click 'OK'.
9.  If you do not want to print some pages, on the preview image on the left, click those pages to delete them.  (The pages you clicked to delete can be displayed again by clicking them again.)
Click HERE for information on supported media types that you can be used with the MX922.
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
