Turn Enable bi-directional support on in the printer's Properties dialog box.
Squyre
With my MP250 printer, when I  try to print now shows in a box on my PC the message " Cannot communicate with the printer.
Turn Enable bi-directional support on in the printer's Properties dialog box."
Looking at my Canon desktop app there appears to be no  'dialog box'.
Please help.
11 REPLIES 11
Squyre
My operating system is Windows 10.
ldybug1964
This worked like a charm for me:
  1. Select Start > Control Panel > Devices and Printers.
  2. Right-click your printer name, then select Printer properties.
  3. Select the Ports tab.
  4. Select the Enable bidirectional support check box.
  5. Click OK.
You instructed the following:
click on Port Tab--this did not show
nor did I see "select the Enable bidirectional support  check box
and no click OK
My Printer is "Pixma MG 7120
and no click OK
Hi rlamartine,
Please double check to make sure you are in the correct location:
 1.  Click on the Windows Start button in the lower left hand corner (and then the Windows System folder if using Windows 10).
 2.  Click on Control Panel.
 3.  Click on View devices and printers.
 4.  Right click the Canon MG7100 series Printer and left click on Printer Properties.
 5.  Click on the Ports tab.
 6.  Place a check in the box next to Enable bidirectional support.
 7.  Click OK.
PlanetClaire
There is no ports tab. None.
Hi PlanetClaire,
What model printer do you own?
What version of Windows is installed on your computer?
Are you using your printer wirelessly?  or with a USB cable?
Cryonic151
I have an mg3050 and the bidirectional option is ticked but the printer is still in an error state, any advice?
Welcome to The Canon Forums, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Forum is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, to go: https://global.canon and select your country or region for your support needs.
Feel free to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
