07-31-2020 10:33 AM
I replaced the ink and no I am getting "processing please wait momentarily" message when I try to print a test picture pattern. I press "stop" and it goes back to home screen. Everything else working, internet connection good. No print jobs stuck in the que. If I go to turn it off, I get the "ending please wait momentarily". Frustrated, any ideas?
08-02-2020 02:20 AM
08-02-2020 10:20 AM
08-03-2020 02:11 AM
I agree the replacement cartridges may be the problem. Bigger problem is having Cann and other printer manufacturers have programmed the printers to only accept their cartridges. There are articles to this affect on line and i believe them. my printer worked fine one day, even with replacement cartridges, and the next day, after a Canon update the printer would not print correctly.
08-07-2020 03:19 PM
Hello.
For testing purposes, restart your Windows or Mac computer. Next, perform a copy directly from the Copy menu of the printer. Does this delay also occur when you perform copies directly from the printer?
08-08-2020 05:16 AM
Not sure what delay you are referring to? Yes the printer is always slow, but that has nothing to do with the failure to print in black and white that is the subject of my post.
one thing i have found is that if i uncheck the box for grayscale printing, and uncheck the box for save ink i do get better results, which is unusual because it goes against the idea of grayscale.
