03-01-2020 05:57 AM
I just purchased/installed a new PIXMA TR4522. Canon Quick Menu does not recognize the printer at all, when I start QUick Menu nothing except Easy Album Ordering Service and My Image Garden. I've went through the installation process several time for the printer and Quick Menu and no luck, I can't even select a printer from the preferences menu, the printer and scanner drop-down selection bars are blank.
03-02-2020 04:38 PM
Hi Hogger1225.
The Quick Menu is not supported for use with the TR4522. On Windows, you may access the optional software through the Start menu (Drag and drop to create new panels in the right side of the Start menu), or through pinning it to the Taskbar while it is open (Right-click the icon on the task bar and select Pin to taskbar). For Mac OS, you may quick-link the icon by dragging it onto the dock; the core executables may be found in the Applications folder >> Canon Utilities folder.
03-02-2020 07:15 PM
03-03-2020 02:36 PM
Hello.
The My Printer program is also meant to be used with older Canon products.
For a listing of the programs that are meant to be used with the TR4520 and TR4522, visit THIS LINK.
03-02-2020 04:38 PM
Hi Hogger1225.
03-02-2020 07:15 PM
03-03-2020 02:36 PM
Hello.
