Pixma MG5300 stopped halfway through printing a photo and wont respond
DarNew
Hi!
Has anyone had a simialr issue where their Pixma MG5300 stopped halfway through printing a photo and wont respond? Because that's exactly what's happened to mine. The unit will powerup, well the Alarm Lamp is permanently on (yellow LED) but nothing else onteh printer will respond. I've tried factory resetting it, I've checked the power supply, but nothing.
Any help you be much appreicated.
1 REPLY 1
James_C
Moderator
Moderator
Hi DarNew,
Let's perform the following steps to resolve the described issue:
1.  Turn off the printer and disconnect the power cord and USB cable.
 2.  Remove paper from the automatic sheet feeder (in the back).
 3.  Gently pull jammed paper out, if any.
     3-1.  If paper is visible from the ASF, use both hands to pull the paper out slowly.
     3-2.  If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
 4.  If the paper tears and a piece of that remains inside the printer, open the printer cover and remove the paper from inside the printer.
 5.  Check ASF with a bright light to check for obstructions.  Remove any if found.
 6.  Open the rear cover to check if the paper is jammed.
 7.  Pull out the cassette and check if the paper is jammed inside the cassette area.
 8.  Load paper back into the ASF or cassette.
 9.  Reconnect the power cord, turn on the printer and confirm that the Alarm light is off. (If there was any jammed paper remaining in the printer, the paper may be automatically ejected.)
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
