08-22-2014 05:06 PM - last edited on 11-04-2023 02:27 PM by Danny
02-25-2022 12:18 PM
I've solved changing the print head with a new one (second hand actually).
It works now.
Regards, Manuela
08-22-2014 05:20 PM
Hi!
To ensure the most accurate information is provided, we will need to know the printer model you are using.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/EmailCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks and have a great day!
08-22-2014 05:34 PM
11-04-2023 02:24 PM
TR470
11-04-2023 02:29 PM
Thanks for joining the conversation, brdurham1! This thread is over 9 years old and deals with a different printer model. We recommend that you start a new thread to address the problem specific to your printer.
Hope to see your post soon!
08-26-2014 09:46 AM - edited 08-26-2014 09:46 AM
Hi jvause919,
Please follow these steps to try to resolve this issue:
1. Confirm that your PIXMA MX700 is powered on.
2. Pull open the paper output tray.
3. Lift the scanning unit (printer cover) completely. The print head will move to the replacement position.
4. Open the inner cover.
5. Remove the ink tanks by pressing the tab of each tank.
6. Raise the print head lock lever.
7. Tilt the print head slightly towards the front of the machine and lift out gently.
8. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
9. Insert ink tanks into the print head.
10. Press the mark <PUSH> on the ink tank firmly until you hear a click.
11. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
12. Close the inner cover and the scanning unit/printer cover.
If printhead error persists, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
09-18-2020 09:00 AM
Hello,
I'm facing the same error with my printer Canon PIXMA IP4200.
I've tried every solution found on the web:
But nothing has changed, the printer still returns the error "correct print head is not installed".
I printed with no problems few days before this error started.
What can I do more?
Thanks
manumart
02-25-2022 12:18 PM
It works now.
Regards, Manuela
