04-02-2016 08:54 AM
PIXMA MP350: The ink tanks do not appear when opening the printer cover. It displays "SCANNER ERROR" on the LCD display. This started after changing the blue ink tank.
04-05-2016 11:36 AM
Hi GvdM,
Canon has not manufactured a PIXMA MP350. Might the model be a PIXMA MP530?
The scanner error is an indication that your PIXMA MP530 is experiencing an internal error. To try to resolve the scanner error, please follow the following steps:
1. Turn off the printer and disconnect the power cord and USB cable.
2. Remove paper from the automatic sheet feeder (in the back).
3. Gently pull jammed paper out, if any.
3-1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
3-2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
4. If the paper tears and a piece of that remains inside the printer, open the printer cover and remove the paper from inside the printer.
5. Check ASF with a bright light to check for obstructions. Remove any if found.
6. Open the rear cover to check if the paper is jammed.
7. Pull out the cassette and check if the paper is jammed inside the cassette area.
8. Load paper back into the ASF or cassette.
9. Reconnect the power cord, turn on the printer and confirm that the Alarm light is off. (If there was any jammed paper remaining in the printer, the paper may be automatically ejected.)
If the above procedure does not resolve the scanner error, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
