03-29-2016 11:07 AM - edited 03-29-2016 11:55 AM
I am trying to put a stack of docs in the ADF and then scan them into individual pdf or jpg files. No matter what I do, I can not make this work. Can someone please step by step me through the setup of this? Thank you.
Tom
04-01-2016 06:50 AM - edited 04-04-2016 01:45 PM
Hi comictommy,
Please click on the Settings button and then Document Scan.
In the Save Settings section, next to Data Format, please choose PDF.
If PDF (Multiple Pages) is selected, all of your pages will be scanned and saved as one PDF file.
If PDF is selected, all of your pages will be scanned and saved as individual PDF files.
03-31-2016 10:40 AM
Hello.
The IJ Scan Utility program controls the scanning function. It appears that the ADF is set to save to multiple-paged PDF files.
Open the IJ Scan Utility program on your comptuer and go to Settings. Once there, click the "Scanning from the Operation Panel" tab on the upper left. You can adjust the setings from there.
If additional assistance is needed, find more help at Contact Us.
03-31-2016 11:01 AM
I do not have the "Scanning from the Operation Panel" button. Here is a screen shot.
and then:
I have been through every tab and not one gives me the option of scanning into individual files.
Thanks!
Tom
03-31-2016 01:32 PM
Hello.
Select the "Scanning from the Operation Panel" tab on the upper left. It is the center of the three tabs next to the picture of the tools.
If you continue to have difficulties with this issue, find more help at Contact Us.
03-31-2016 02:08 PM
Michael,
I am sorry. I am computer literate and I feel like a fool here. Please tell me where the setting is in the picture below. I do not see an option to determine one vs. many sheets in the same PDF. Thank you.
Hi comictommy,
04-06-2016 07:49 AM
