11-19-2015 11:50 PM
Just installed Windows 10 version 1511 for 64 based systems and trying to download and instal the driver(s). It's impossible , allways windows informs that the "IJ driver installer has stopped working. A problem caused the program to stop working correctly etc, etc." I've tried also to install in 8.1 compatiblity mod also without success.I've tried to use also Microsoft Explorer instead of Edge, also no luck.
11-28-2015 12:53 AM
Yes, I have noticed the same issue, when installing the MP driver setup on Windows 10 ver 1511, it fails to complete the install, causing the rest of the install to fail. Printing works, but the scanning doesn't because it fails to register the printer as a scanner. My only option was to install the previous build of Windows 10 10240, then upgrade from 10240 to 10586.
