Reply
Highlighted
New Contributor
Lens compatibility
I currently have the C100 mark 2 and am very pleased with the low light performance that I experience doing church weddings and in particular receptions. One area that the C100 appears to fall short on however is the continuous focus. It appears that only STM lenses will continuously focus on this model. Is that true? I would perfer to be using an "L" lens. The only time I really need this is during the processional, but its an important piece.
And does the C200 have the same limitation of Continuous focus only working with STM lenses?
Re: Lens compatibility
Hello Valen,
On the EOS C100 Mark II you can use Continuous AF with EF lenses that have an AF/ MF switch present on them.  On the camera, go into the AF Mode submenu [Camera Setup> AF> Mode] select [Continuous] and then press the joystick.
The setup for the EOS C200 is identical to the EOS C100 Mark II.
New Contributor
Thank you for the reply. Now when I try to do that with anything but an STM lense the AF doesn't work on the C100 mark II? Am I doing something wrong?
Hello Valen,
The EOS C100 Mark II has a focusing mode called Face AF which is only compatible with STM lenses, but that is distinct from Continuous AF.  I believe Face AF is probably what you are referring to instead, as Continuous AF is not limited to strictly STM lenses.
powered by Lithium
