02-12-2015 08:55 PM
I'm having trouble connecting my c100 mkii to my wifi network. After putting in all the network settings I go to Network Settings > Select and then select my network, but nothing happens. It simply returns me to the previous menu without doing anything, and I cannot get the network status icon to appear in the corner of my display.
Am I simply setting up my network settings while there's another step to connect? I've read the manual back and forth and can't figure it out.
- Adam
02-15-2015 06:10 PM
Hello AdamRosenberg,
Depending on the function and type of Wi Fi connection you're trying to make, there are several variables to consider and multiple steps involved. Especially since we're dealing with setting up an EOS C100 Mark II, we highly suggest utilizing either the technical support hotline at 1-855-CINE-EOS or using the Canon online support web site to send Canon technical support an email. This would be beneficial to you as our agents could assist in a step by step manner versus using this forum, which is more difficult to use in a technical support capacity.
02-15-2015 06:10 PM
