videos recorded on Vixia r500 sdcard will not playback on tv
richie14
3 REPLIES 3
rs-eos
What specifically are you trying to do?  Did you perhaps insert the SD card into your TV? For those TVs that have SD card slots, the media that can be played would be dependent upon the manufacturer.
You should be able to connect the camcorder to the TV via an HDMI cable and then play the footage on the cam.
Or, edit the video to an appropriate format that the TV would be able to consume.
Ricky
Camera: EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L
richie14
SD card records all videos but does not recognize some on tv or computer. Thank you
rs-eos
I still don't understand what it is you are trying to do.
Ricky
