09-03-2014 08:01 PM
OK, I confess, I am not overly bright but this is the first time that I have been unable to figure out how to insert a battery. I just received a VIXIA HF G30 camcorder and have been beaten by the wireless controller battery compartment. No matter what I try, I cannot get access to insert the battery. Sure would appreciate some help, thanks. Ted
09-05-2014 08:54 PM
Hello tevans9129,
The WL-D89 uses a CR2025 button type battery. It is located behind that battery tray which slides down. To open, hold the remote in your right hand (flipped over on it's back) and hook the fingernail of your left index finger into the little batch which acts like a spring and pull it towards you. At the same time, use the fingernail of your right thumb to pull down the battery tray down and out. This will allow you to change out the battery pack.
09-05-2014 08:54 PM
Hello tevans9129,
09-05-2014 09:49 PM
Thanks for the response Tim. I have never seen such an arrangement to get access to a battery before. It certainly was not engineered for us old people that have lost some of our dexterity. Thanks again. Ted
