03-17-2017 11:02 AM
We're using our new Canon HF G40 to record the sermons at our church. We are recording in 1920 X 1080 29fps. We are using a high speed 64 gb memory card. At about 30-35 minutes the camera starts a new clip. The sermons are typically about 40-45 minutes. Because of the camera splitting video into 2 clips, we have to import them into video editing software to combine them into one video before I can upload it online. Is there a setting that I'm missing in the camera that would allow me to remove the clip length limit? The memory has plenty of room so that's not causing the limit. Any ideas or suggestions would be greatly appreciated. Thank you.
03-17-2017 03:16 PM
What would happen if I format the SD card for NTFS in Windows? Would the camera not recognize it?
03-17-2017 03:23 PM
That would not be a good idea and probably will cause problems. The NTFS format won't work with the camcorder. Believe me I've thought of doing the same thing myself. I may have even tried it. Either way it is always safest to format the card in the camcorder.
03-17-2017 03:30 PM
You could always call our team. They're happy to walk you through the best way to get the most out of your situation!
The number is 1-800-OK-CANON (800-652-2666) from 10am to 10pm (ET) during the week.
03-17-2017 04:06 PM
Thanks. I called Canon, but they're only suggestion was to lower the resolution. Due to the camera file system being FAT32 I'm limited to 4GB clips. The canon representative agreed that Canon needs to look into the option of having a different format that allows us to record longer videos without creating multiple clips.
03-17-2017 04:18 PM
Thanks for the update. I don't think this is unique to Canon. The only camcorders I have that doesn't break the clips into files is are tape based (miniDV and 8mm) and prepping them for upload is an even longer process. It would be nice to have one continuous clip for each scene. If NTFS is out of the question then what about ExFAT since both PCs and Macs will recognize that file system It's a thought.
03-17-2017 04:49 PM
Agreed. I think Canon and the other companies need to be seriously discussing this. Especially since 4k video (and it's larger file sizes) is becoming more popular on the consumer level.
03-28-2021 09:29 PM
03-28-2021 10:35 PM - edited 03-28-2021 11:57 PM
@Penniwinkle wrote:
We just bought a brand new video recorder camera to record a 90 minute presentation and my partner didn't notice it turned itself off after 15 mintues.
Why? And HOW to work around? A 64 gb chip is worthless if it only records for 15 minutes.
I don't know why it would do that. Page 44 In the User Manual:
Did it happen just the one time or does it happen everytime ?
Was this on battery power or using the DC power adapter ?
Was it connected to a LANC remote control and/or on-camera (field) monitor? Connections should always be made before the camcorder is powered on.
Have you tried changing the SD card ?
As for split mp4 files, the Pixela Data Import Utility will join them:
And on page 39
04-05-2021 01:37 PM - edited 04-05-2021 01:38 PM
Given the lack of feedback I think it's reasonable to assume that this was a case of 'operator error' and was not due to a fault with the camcorder per se.
03-25-2018 09:02 AM
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
